Nuevo controlador modelo planar: comfort control
Iniciado por curras, Marzo 13, 2021, 11:54:08 am
curras
Marzo 13, 2021, 11:54:08 am Ultima modificación: Enero 27, 2022, 12:25:27 pm por falco
Pues parece que ya está a la venta el nuevo controlador para las planar:
https://shop.autoterm.com/699-comfort-control-new-panel 90€
He buscado el manual a ver que funciones nuevas trae:
Así a bote pronto he visto:
- posibilidad de poder activar los 3 temporizadores simultáneamente y programar su duración :
Set working duration of the heater.
Duration can be set from 30min to 720min* with increasing step of
5min.
*up to 120min for liquid heaters
Creo que lo de 720 mins es un error de redacción.
Y parece q ahora ya se puede apagar el ventilador, además de programar el apagado....
3.3. HEATING
In "Heating" menu different operation modes for heating can be set,
depending on the connceted heater.
To set heater modes select the "Heating" menu from the main menu by
pressing the knob once and then select one of the heating modes:
Temperature can be set in a range from 0°C up to 30°C, with step of 1°C.
Work time can be set in a range from 30 min up to infinity, with step of:
• 5min up to 2h; • 20min up to 12h; • after 12h next step is ∞.
Heating modes for air heaters:
TEMPERATURE MODE -
Heater will maintain set temperature by reducing the heating
power, without shutting off the combustion process.
POWER MODE - Heater will operate constantly at set power level.
HEAT + VENTILATION -
Heater will operate till the temperature is reached 1°C above
the set temperature, shut off the combustion process and
start to ventilate till the temperature drops 5°C below the set
temperature. When temperature drops, heating starts again.
THERMOSTAT MODE -
Heater will operate till the specified temperature is reached
then shuts off the combustion process and ventilation. After
the temperature drops by specified degrees heating will start
again.
Eso es lo que me ha parecido más interesante, luego también han añadido opciones de configuración, calibrado de sensor, ajustar el voltaje mínimo de batería,  y alguna cosilla.
Hay varios videos por youtube pero todos en alemán y la traducción es bastante mala.
A ver si alguien tiene mas info y nos ilumina. Pero parece que tiene buena pinta, si todo esto es así es el punto que le faltaba a las planar por mejorar.
Atolondrao
La duda es si se podría instalar este controlador en una planar 2D que es la que yo tengo. Algo que me fastidia un poco es que el ventilador no se apague nunca, aunque puedo vivir con ello sin problemas. Por lo que parece solucionan eso con este controlador...
Vykingo
Me interesa.
Tengo una planar 2d en una vito y está semana quiero comprar otra para una L2H3.
No se si con una 2d será suficiente, pero es que en la vito me aso si la pongo a media potencia.
Otro tema es si este regulador merece la pena como para comprarlo a parte y subir 100 EU el precio.
En las tiendas habituales no lo venden actualmente.
curras
Cita de: Vykingo en Marzo 18, 2021, 00:47:13 amMe interesa.
Realmente sube 30 de diferencia al anterior digital. Yo en cuanto pueda lo instalo
LordWhale
Interesante. Si alguien lo llega a probar será algo a tener en cuenta antes de montarlo todo!
Aayaats
Perdonad mi torpeza pero con este nuevo controlador se solucionaria el tema del antiguo que si querias dejar la calefacción a 15 grados por la noche solo se encendera el ventilador cuando bajemos de esta temperatura y no como antes que el ventilador estava siempre encendido y solo se apagava/encendia el quemador?
Asturman
Hola Aayaats. Precisamente esa es una de sus principales mejoras respecto al anterior.
LordWhale
Por cierto.. he visto que hay tiendas que venden el flow5s con el confort control pero ponen que necesita una modificacoin para funcionar mas de dos horas seguido... sabeis si es así o si eso simplemente se consigue con este mando nuevo  .loco2
Isidoro
rob1970
Nacho41
Hola a todos! Yo la tengo instalada en la furgoneta, con el mando nuevo, no he probado otra, así que no sabría decirte bien  las diferencias, la suelo poner en modo temperatura por el dia, aquí fijas la temperatura y enciende hasta alcanzarla, una vez hecho esto el ventilador continua funcionando pero mucho más lento ( tendría que probarla mejor, porque no se si se acaba parando el ventilador, creo que no)  la combustión también continua encendida.
Por las noches pongo el modo termostato, que al alcanzar la temperatura fijada se apaga del todo, ventilador y combustión, lo malo a mi parecer es que cuando vuelve a encender el ventilador se pone a tope y hace bastante ruido hasta que va cogiendo temperatura el habitáculo que reduce la velocidad.
Seguiré trasteando, si alguno tiene más información bienvenido sea.
Tomateje
Cita de: Nacho41 en Enero 04, 2022, 17:04:19 pmHola a todos! Yo la tengo instalada en la furgoneta, con el mando nuevo, no he probado otra, así que no sabría decirte bien  las diferencias, la suelo poner en modo temperatura por el dia, aquí fijas la temperatura y enciende hasta alcanzarla, una vez hecho esto el ventilador continua funcionando pero mucho más lento ( tendría que probarla mejor, porque no se si se acaba parando el ventilador, creo que no)  la combustión también continua encendida.
Buenas Nacho, nos puedes decir algo más del funcionamiento del aparato?
Miserjo
Hola, yo tengo montada la 4D con el mando nuevo. Al igual que Nacho es mi primera calefacción, y no puedo contrastar
Como bien dice Nacho, tiene varias maneras de encenderla. Yo aún sigo intentando hacerme con ella.
Tiene 3 temporizadores distintos que puedes programar para distintos encendidos y configurar el tiempo de apagado. Puedes tener los 3 temporizadores al mismo tiempo ,y elegir distintos días y horarios de encendido.
Puedes escoger distintos días de la semana, individualmente.
En modo termostato es verdad que se apaga por completo, pero al arrancar, el ventilador se pone a tope y de noche molesta, a mí me despertó.
Yo de noche la enciendo en modo potencia, y la coloco al mínimo o casi al mínimo depende de la temperatura exterior, aquí mi duda es si se puede colocar alguna temperatura de referencia, la tengo poco tiempo, y sigo probando cosas.
Luego tiene otra opción de encendido que es calefacción + ventilación.
Pero aún no lo he probado.
Espero sirva de ayuda
argioberena
Cita de: Miserjo en Enero 24, 2022, 17:58:32 pmHola, yo tengo montada la 4D con el mando nuevo. Al igual que Nacho es mi primera calefacción, y no puedo contrastar
Buenas, y si pones modo temperatura o termostato se te apaga? Yo no hago carrera, cada 20 min más o menos se me apaga del todo ( como si se enfriase) y le cuesta horas alcanzar una temperatura agradable.  Tengo la salida de la calefacción con tubo de 90, y luego al final una reducción a 60, y un registro con un tubo para que coja aire del habitáculo.
Miserjo
Cita de: argioberena en Enero 26, 2022, 11:23:10 amBuenas, y si pones modo temperatura o termostato se te apaga? Yo no hago carrera, cada 20 min más o menos se me apaga del todo ( como si se enfriase) y le cuesta horas alcanzar una temperatura agradable.  Tengo la salida de la calefacción con tubo de 90, y luego al final una reducción a 60, y un registro con un tubo para que coja aire del habitáculo.
En modo temperatura, no lo sé.
En termostato si. Se apaga completamente, y cuando baja x grados de la temperatura marcada en el termostato, se vuelve a conectar.
