Noviembre 15, 2026, 02:23:27 am
Cargador solar portatil USB?
Iniciado por eufecio, Abril 25, 2020, 12:23:26 pm
eufecio
Abril 25, 2020, 12:28:48 pm #1 Ultima modificación: Abril 25, 2020, 15:48:55 pm por eufecio
https://es.aliexpress.com/item/32715816541.html?spm=a2g0o.detail.0.0.5e277686TTSmd5&gps-id=pcDetailFavMayLike&scm=1007.12873.140318.0&scm_id=1007.12873.140318.0&scm-url=1007.12873.140318.0&pvid=eb7760c9-fba3-4a02-b749-dcd75ec2c534&_t=gps-id:pcDetailFavMayLike,scm-url:1007.12873.140318.0,pvid:eb7760c9-fba3-4a02-b749-dcd75ec2c534,tpp_buckets:668%230%23169576%231_668%23808%237756%23623_668%23888%233325%2311_668%232717%237560%23246
https://es.aliexpress.com/item/32856592236.html?spm=a2g0o.detail.0.0.5e277686TTSmd5&gps-id=pcDetailFavMayLike&scm=1007.12873.140318.0&scm_id=1007.12873.140318.0&scm-url=1007.12873.140318.0&pvid=eb7760c9-fba3-4a02-b749-dcd75ec2c534&_t=gps-id:pcDetailFavMayLike,scm-url:1007.12873.140318.0,pvid:eb7760c9-fba3-4a02-b749-dcd75ec2c534,tpp_buckets:668%230%23169576%231_668%23808%237756%23623_668%23888%233325%2311_668%232717%237560%23246
https://es.aliexpress.com/item/32542740844.html?spm=a2g0o.detail.0.0.5e277686TTSmd5&gps-id=pcDetailFavMayLike&scm=1007.12873.140318.0&scm_id=1007.12873.140318.0&scm-url=1007.12873.140318.0&pvid=eb7760c9-fba3-4a02-b749-dcd75ec2c534&_t=gps-id:pcDetailFavMayLike,scm-url:1007.12873.140318.0,pvid:eb7760c9-fba3-4a02-b749-dcd75ec2c534,tpp_buckets:668%230%23169576%231_668%23808%237756%23623_668%23888%233325%2311_668%232717%237560%23246
https://es.aliexpress.com/item/4000097056893.html?spm=a2g0o.detail.0.0.5e277686TTSmd5&gps-id=pcDetailFavMayLike&scm=1007.12873.140318.0&scm_id=1007.12873.140318.0&scm-url=1007.12873.140318.0&pvid=eb7760c9-fba3-4a02-b749-dcd75ec2c534&_t=gps-id:pcDetailFavMayLike,scm-url:1007.12873.140318.0,pvid:eb7760c9-fba3-4a02-b749-dcd75ec2c534,tpp_buckets:668%230%23169576%231_668%23808%237756%23623_668%23888%233325%2311_668%232717%237560%23246
AntonioOC
Abril 25, 2020, 12:34:43 pm #2 Ultima modificación: Abril 25, 2020, 12:36:36 pm por AntonioOC
Yo tengo uno de esos de la marca suaoki de 25w, para cargar el móvil me va bien incluso para recuperar algo de carga de la powerbank, son lentos cargando pero van bien, en una mañana con buen sol se carga el móvil del 15 al 99%.
También te comento que no se porqué motivo un iPhone no lo carga, en cambio un android si, probado los dos en el mismo momento.
Te dejo enlace del que yo tengo .
https://m.es.aliexpress.com/item/32804123978.html
Enviado desde mi Mi A2 Lite mediante Tapatalk
eufecio
Cita de: AntonioOC en Abril 25, 2020, 12:34:43 pmYo tengo uno de esos de la marca suaoki de 25w, para cargar el móvil me va bien incluso para recuperar algo de carga de la powerbank, son lentos cargando pero van bien, en una mañana con buen sol se carga el móvil del 15 al 99%.
Tiene buan pinta y buenas calificaciones, seguramente lo compre
Soy de android ,asi qeue no tendre problemas
Lo ve seguro como para dejarlo en la luna del coche mientras estas de ruta unas horas?
Hay otros que tienen bateria incorporada, como si cargasen un powerbank y del powerbank se carga el movil...
Creo que el tuyo es mejor, porque no dependes de si falla el powerbank  a la larga, siempre cargara
AntonioOC
Cita de: eufecio en Abril 26, 2020, 22:42:17 pmTiene buan pinta y buenas calificaciones, seguramente lo compre
Si vas de ruta con mochilas puedes llevarla colgada en la espalda e ir cargando la powerbank, se calienta bastante y no me daría confianza de dejarla en la luna por el efecto lupa....
eufecio
Cita de: AntonioOC en Abril 27, 2020, 00:05:09 amSi vas de ruta con mochilas puedes llevarla colgada en la espalda e ir cargando la powerbank, se calienta bastante y no me daría confianza de dejarla en la luna por el efecto lupa....
La quiero basicamente para la furgo, por tener siempre algo de emergencia,igual dejandola fuera en el techo con el cable por dentro  de la furgo para cargar powerbanks
no acumula bateria verdad? o sea que si no hace sol no funciona, por las tardes funciona bien?
Yo suleo hacer rutas de ciclsimo de montaña y suelo estar toda la mañana por ahi
Jeyzee
Si conectas una powerbank a la placa asi no perderas batería. Y luego usas esa powerbank cargada solarmente para cargar el movil. No se si te referías a eso
Enviado desde mi Redmi Note 8 mediante Tapatalk
AntonioOC
Cita de: eufecio en Abril 27, 2020, 14:13:08 pmLa quiero basicamente para la furgo, por tener siempre algo de emergencia,igual dejandola fuera en el techo con el cable por dentro  de la furgo para cargar powerbanks
Si no hay sol no hay carga, mientras haya buena radiación solar funciona bien .
Dejarla fuera si te fías...
Con una powerbank de 20ah tienes para muchas cargas.
montanes68
Otro mas q tiene el Suaoki, lo recomiendo, tiene dos salidas de usb para cargar a la vez 2 moviles, 2 powerbanks, recargar 2 aparatos vamos...nosotros lo dejamos puesto en el salpicadero mientras q vamos en marcha, otras veces lo hemos colgado gracias a sus 3 mosquetones del porton trasero abierto, si hay sol no tarda tanto en cargar, es ecologico, no consume y gasto 0 en cargar gracias a Don Lorenzo  .meparto
Mercedes Viano Marco Polo 2.2 CDI 150 cv
eufecio
Cita de: Jeyzee en Abril 27, 2020, 15:36:35 pmSi conectas una powerbank a la placa asi no perderas batería. Y luego usas esa powerbank cargada solarmente para cargar el movil. No se si te referías a eso
A eso me refiero, pero lo de calentarse mucho y no estar presente no me mola...
Cita de: AntonioOC en Abril 27, 2020, 17:03:43 pmSi no hay sol no hay carga, mientras haya buena radiación solar funciona bien .
Ese es mi plan, tengo dos powerbank de 20ah y sera un buen complemento, en escapadas de 7 dias me quedo corto
Pero me da un poco de miedo lo de dejarla tanto en la luna como en el techo mientras yo no este presente, normalmente dejo la furgo escondida en el monte para hacer rutas
Pero que llegue a incendiarse es dificil no ? es la duida que tengo ,paso de quemar el monte o la furgo
Cita de: montanes68 en Abril 27, 2020, 19:12:59 pmOtro mas q tiene el Suaoki, lo recomiendo, tiene dos salidas de usb para cargar a la vez 2 moviles, 2 powerbanks, recargar 2 aparatos vamos...nosotros lo dejamos puesto en el salpicadero mientras q vamos en marcha, otras veces lo hemos colgado gracias a sus 3 mosquetones del porton trasero abierto, si hay sol no tarda tanto en cargar, es ecologico, no consume y gasto 0 en cargar gracias a Don Lorenzo  .meparto
Te refieres al modelo que puso antonio? gracias
AntonioOC
Abril 27, 2020, 22:45:45 pm #10 Ultima modificación: Abril 27, 2020, 22:47:31 pm por AntonioOC
Cita de: eufecio en Abril 27, 2020, 22:07:46 pmA eso me refiero, pero lo de calentarse mucho y no estar presente no me mola...Ese es mi plan, tengo dos powerbank de 20ah y sera un buen complemento, en escapadas de 7 dias me quedo corto
Si tienes dos powerbank de 20ah salidas de casa con carga te da para 7 días para cargar el móvil de sobra,  más a más las puedes cargar con el coche conectandolas al mechero....  Primero pruébalo y mira si te va bien Pero para 7 días te diría que de sobra .
eufecio
Cita de: AntonioOC en Abril 27, 2020, 22:45:45 pmSi tienes dos powerbank de 20ah salidas de casa con carga te da para 7 días para cargar el móvil de sobra,  más a más las puedes cargar con el coche conectandolas al mechero....  Primero pruébalo y mira si te va bien Pero para 7 días te diría que de sobra .
Es el movil- gasto muchas pilas 1850, linterna, luces, gps... me duran unos 5 dias y como no me muevo mucho esos dias no lo suelo cargar con el coche mas de 30 minutos de desplazamientos y no me llega, imagino que con la placa solar me dara lo que me falta
montanes68
CitarOtro mas q tiene el Suaoki, lo recomiendo, tiene dos salidas de usb para cargar a la vez 2 moviles, 2 powerbanks, recargar 2 aparatos vamos...nosotros lo dejamos puesto en el salpicadero mientras q vamos en marcha, otras veces lo hemos colgado gracias a sus 3 mosquetones del porton trasero abierto, si hay sol no tarda tanto en cargar, es ecologico, no consume y gasto 0 en cargar gracias a Don Lorenzo  .meparto
Hola,
Si, es el mismo modelo.
