Lista para pedir baterias Agm o Gel. PEDIDOS HASTA EL 23 DE OCTUBRE
Iniciado por anlupe, Agosto 27, 2013, 22:07:25 pm
Maerus
Actualizada.
NOMBRE                          BATERIA                   CANTIDAD
01-Anlupe.                       85 Amperios.Agm.              1.
02-harry85                     100 amperios.Agm               1
03-Jalminha                    85/100 Ah     .Agm/Gel        1
04-Antmartin                   100 ah          Agm               1
05-Malamock                  85 Amperios.Agm                 1
06-Karionte                     85 Ah          Agm/Gel           1
07-cheeper                       100Ah         agm                1
08-Inuco                           85 Ah          agm               1
09-Yoanit                         200Ah          Agm               1 (o 2 de 100Ah)
10-panxe                       85Ah/100        Agm/gel         1
11-RecorriendoMundo       100Ah          Agm                1
12-junsen                        100Ah          Amg                1
13-naturevan                    85Ah             AGM              1
14- beco                           100 Ah            AGM             1
15-Calzoneta                    85Ah           AGM / Gel         1
16-beco                          85 / 100 Ah   Agm / Gel         1
17-caferacer28                    100Ah        gel              1
18-OKER                             100Ah        AGM                1
19-Maerus                       100Ah           AGM                 1
20-Koyi                           150 Ah          AGM/GEL          1
21-Os                               120a            AGM/GEL         1
22-chapel                   100ah/120ah     AGM/GEL          1
23-Jimymax.                  100 ah.           AGM                1 (camperbaos)
24-Israher.          1.  100ah                                         1
25-Jalons                       100Ah AGM                           1
26-donvito                    150 Ah             AGM                1
27-ARION                     85/100 Ah   Agm/Gel               1
28-quinuria                   100/120 Ah      AGM                1
29-Monche                   100 Ah              AGM               1
30-Bigotes                    100 Ah              AGM              1
31-jjesit                        120 Ah       AGM                    1
32-Peterpan.                 92 ah       AGM  Exide EK 920.. 1        1
33-axma                        100 Ah       GEL                      1 camperbaos
34-nozone                       100 Ah       AGM                   1
35-salva2                         85/100 Ah       AGM/GEL      1
36-Mochu                          100Ah AGM                        1
37-jjota                           250 ah     AGM                    1
38-hetf1eld.                      100ah    GEL CAMPERBAOS   1
39-Muxarra                         85ah    AGM                       1
40-Pachamama                  85/100ah   AGM                1
41-rogeliano                     100ah     Gel                     1
42-Furgoazkarra              200AH    AGM                     1
Maerus
Furgoazkarra
Blog                                  http://ipar-otsoakmushingteam.blogspot.com.es/
Peugeot Boxer Dangel 4x4   http://www.furgovw.org/index.php?topic=180268.msg1447407#msg1447407
Opel Vivaro                        http://www.furgovw.org/index.php?topic=21018.msg274410#msg274410
beco
Ahora resulta que estaba apuntado 2 veces.
Pongo lista actualizada.
18-OKER                             100Ah        AGM                1
Hilo de las Mitsubishis L-300 y SpaceGear: http://www.furgovw.org/index.php?topic=221134.0
Mi Exfurgo:   L300 4x4: http://www.furgovw.org/index.php?topic=204741.0
Nuevo proyecto:   Renault trafic 2.0: http://www.furgovw.org/index.php?topic=293373.0
CASPER30
Actualizo lista que nos borrasteis a mi CASPER30 y a deiviz
18-OKER                             100Ah        AGM                1
43-CASPER30                     100ah    GEL CAMPERBAOS   1
44-deiviz                           100ah           AGM                  1
OKER
Joder,no se que hacer,si cambiar y pillar la de GEL o que,alguien que me ilumine que me parece muy poca diferencia de precio para ser 100AH de gel
-FUTBOL,-CARRERAS Y +FURGOS EN LA CARRETERA
jalminha
Yo a igual precio lo tengo claro...GEL
Enviado desde mi GT-I9000 usando Tapatalk 2
CASPER30
Cita de: OKER en Septiembre 18, 2013, 23:29:29 pm
Hola.
Que jaleoo ehh   .meparto
Es que nos vuelven locooo  .panico   Con lo facil que es cuando no hay elección.
Por lo que he podido leer en otros foros y pedir información a las tiendas estas son las diferencias que hay que tener en cuenta, aunque finalmente recomiendan la AGM, que va en contra de los que las venden, hablando de dinero, logicamente.
Esto es una comparativa a grandes rasgos de las de andar por casa y que se puede entender por todos, aunque te haga todavia pensartelo más con cual quedarte  ;D
Seguro que hay algún entendido que te pueda hacer ver mejor la diferencia entre las dos.
                                              AGM                                  GEL
DESCARGA PROFUNDA             85%                               CASI 100%
POSICIÓN VERT o HORIZ.         V/H                                     V/H
TENSIÓN DE CARGA                 PRACTICAMENTE IGUALES EN LAS DOS
CICLOS DE CARGA                   PRACTICAMENTE IGUALES EN LAS DOS
VELOCIDAD DE CARGA             ALGO MEJOR EN LA AGM
PRECIO                                   MÁS BARATA LA AGM
Decir que no se deben conectar en paralelo una AGM y GEL.
Espero que te sirva un poco la info  :)
yoanit
Cita de: CASPER30 en Septiembre 18, 2013, 23:52:10 pm
Hola.
                                              AGM                                  GEL
Tengo entendido que la AGM soporta mejor tanto una carga rápida como una descarga rápida, por lo que creo que es un factor muy a tener en cuenta según nuestra situación, sobre todo el tema de la descarga. Si no fuese así corregirme por favor
Peugeot Boxer L2H2 (Camperizando)
http://www.furgovw.org/index.php?topic=273069.0
CASPER30
Cita de: yoanit en Septiembre 19, 2013, 00:00:56 am
Yo también lo tengo entendido así.
Pero la de GEL puede tener la descarga más profunda que la de AGM.
OKER
Pues os agradezco las aclaraciones pero creo que aunque la diferencia es minima,para el rendimiento que yo le voy a pedir a la bateria,la AGM me vale y me sobra
Un saludo y a ver si le damos cañita al tema y se aligera esto
ALACRAN
hola:
Llego a tiempo?? cuando teneis pensado cerrar la lista??y los precios donde puedo ver
Gracias un saludo
albertuti
me apunto con vuestro permiso para una para el hueco de la viano
saludoss
18-OKER                             100Ah        AGM                1
45-albertuti                       85/100 Ah     AGM              1
Jativa87
Otro más para la compra
18-OKER                             100Ah        AGM                1
46-Jativa87                        100 ah    GEL CAMPERBAOS  1
