CC Tablet de 10" Zenithink Z102 GPS-HDMI opcion 3G. RECIBIENDO!!!
Iniciado por etorkizun, Septiembre 19, 2011, 22:17:06 pm
gastonjp
I shouldn't be talking to you, being a mini (real not BMW) enthusiast I'm a sworn enemy to any VW fans lol
I'd go for the 4gb from Chinagrabber and then buy a good sized SD card, that way you know your getting a DISCO model that can be flashed and get a good battery, most apps will store large amounts of data will do it on the SD card anyway, like sat nav programs.
I wouldn't know about the Zenithink having 2.3, that sounds more like 2.2 edited to look like 2.3
It's difficult to tell with that video, but a DISCO FT3 runninng FunyComb, Tim5a or 6a will give a quadrant score of over 400, that's nearly twice what a stock FT3 will score.
The question is if you want support for customs roms or not, if you do then a DISCO FT3 is the only option, although there is one for the P041 being worked on.
Can you tell me why my sisters water cooled type Type2 (T3) keeps cracking the mounting plate between the back of the engine block and the automatic gearbox ?, we're running out of crankshafts lol
No hay traduccion simultanea como en el congreso please  .sombrero
CASPER30
Buenas. parece ser que tiene mas opciones la z102 de poder actualizarse en futuro muy proximo....
voy a buscar algo mas.
etorkizun
si es verdad que lleva 2.3, porque en otras paginas venden clones con android 2.2, es un dato a tener en cuenta REPITO, pq se actualizará a android 4.x
ademas se supone que skype sacará más soporte para 2.3 para videoconferencia
PERO ESO DE QUE TODOS BUSQUEMOS INFORMACION esta bien
tnttgn
[*imagen borrada por el servidor remoto
[/quote]
Si me lo puedes pedircon mi tablet ponmelo.
gracias!
tnttgn
Cita de: etorkizun en Octubre 24, 2011, 13:36:50 pm
es un ejemplo... hay cienes de modelos, no te vale con la funda esa?
sobre la z102:
http://www.slatedroid.com/topic/23668-anyone-know-flytouch-5-base-on-a9-tablet/page__p__255276#entry255276
yo cogia la FT3. si no hay nada donde la compres ya la buscaré yo cuando la tenga.
era por tenerlo todo el mismo dia, ademas, incluso mas barato también.
sl2
etorkizun
tienes el vendedor en el primer post...
por cierto, mas datos a favor de la z102:
CitarOK the Zenithink z102 have arrived yes 100% flytouch/superpad exterior,came in white-box ZEPAD written on it,been inside 1 to start 2 x 4,000mah battery set-up,different motherboard to superpad models Disco.po41,etc on the preformance done a few things at moment impressed by most
1, turning on tablet to home screen about 30 to 40 seconds very fast against any other superpad/flytouch
2,touch is very different to flytouch,it is very responsive and smooth
3,loaded a few games angrybirds,driving game,labyrinth,the Graphics are a lot clearer than on flytouch ARM 11,very quick loading time much much faster than flytouch,G.sensor worked correct on 3 games that needed it
4,hit youtube,did a bit of google searching yet again much better quality picture and 2 to 3 times faster loading time then any superpad running ARM 11,
5 did not drop wifi stayed connected until i turned off after 3 hours
6,full charged battery i'd say it would last 3.5 to 4 hours on wifi
7,comes routed
8, for those who watech BBC IPLAYER the voice and mouth movement SYNC works perfect you have a button on top menu bar on the screen of pad right side which plays App*e ip*ad 5 html software etc and also flash mode which needs switching for flash content or 5html
9,2 point multi-touch works fine
10, running FLASH PLAYER 11.1
11,some nice live wallpaper
12, FULL ANDROID MARKET PAID AND FREE ACCEPTS PAID APPS DOWNLOADS
13, you can actually see the screen outside in the sun not big thing but whats the use of having a pad if you can only use in-doors on such a beautiful day
14, you can put a security lock code to stop tampering
a couple of downsides*************************
manual is a disgrace no proper instructions/directions for some 1 new with Android they would be buggered,but saying that it as the basics
gps switching on by its self after going into MAPS,NAVIGATION it is not turned on in settings,and can only be turned off by turning off tablet
but overall a much smoother tablet than flytouch no freezes no crashes and a lot faster surfing the net
UPDATE just taken a tablet out on a co-pilot navigation tour and i have no idea what the navigation hardware is inside these ZENITHINK tablets Z102 is! BUT it did not need the external antenna at all,and i have to say that impresses me a lot,as i have sold many many superpad/flytouch models and they just would not work properly without a antenna,i even picked up the satelitte fixes while sat in the house
and i am not just saying this i have 70 flytouch/superpads to sell so before i put these in my shop i am selling the others 1st lol
BEEN using some *pple *pad HTML5 software and i mean great
been left on over a day now in sleep mode and still going strong
OK my own personal thoughts on the Zenithink Z102 after selling in excess of 800 tablets from 7"-8"-10" in 10 months,i have sold many many flytouch/superpads with gps etc?With the Zenithink z102 as it as the same exterior as the superpad/flytouch models? for the cost of a 10" tablet having multi-touch-gps-cortex A9-against the same looking superpad/flytouch,or any other priced in the same bracket range,i would buy a Zenithink Z102 the overall preformance is very very good.I do not say this lightly as i bought Zenithink zt180 when i 1st started out and they were sh*t,i have not bought a Zenithink since for 10 months,but i thought i would look at these.and they get 9/10 just the gps issue to me needs fixing
jabalinketevi
Arremangate moza y vente pal prao ke te voy a enseñar lo ke tengo guardao
Arremangate moza y vente pal rio ke te voy a enseñar como esta de crecio
jabalinketevi
Hola.puedo pedir yo una tablet? como y donde se hace el ingreso?. Gracias .
mensaka36
Cita de: jabalinketevi en Octubre 24, 2011, 17:45:41 pm
Copia y pega en la lista de mas arriba,especifica el modelo que quieres y si quieres funda-teclado.
jabalinketevi
Octubre 24, 2011, 18:27:21 pm #385 Ultima modificación: Octubre 24, 2011, 18:31:51 pm por jabalinketevi
1. Mensaka36 (Flytouch 3 + funda-teclado)Málaga
2. JESUS F.C (Fly touch 3 + teclado---San Fernando (Cadiz)
3. tnttgn (Flytouch 3 sin funda-teclado a TARRAGONA)
4. gael160963 (SOLO la Dropad A8x)
5. Isakis (flytouch 3 + funda teclado - Navarra) 2 tablets y 2 teclados
6. casper30
7. etorkizun  (Flytouch 3 + funda-teclado) BILBAO (igual tb la Z102)
8. Irina (Flytouch 3 + funda-teclado Valladolid)
9. windrodrigo (Zenithink Z102 Cadiz)
10. Motxilo   (Flytouch 3 + funda-teclado) BILBAO, GETXO, BASAURI
11. txipintxo (Flytouch 3 + funda-teclado GIPUZKOA)
12. Merlindur (Flytouch 3 + funda-teclado Elorrio)
13. Belenek (Zenithink + funda Z102 GIPUZKOA)
14. songo(Zenithink Z102 + funda-teclado GIPUZKOA) 2 tablets y 2 teclados
15. bulmocha(Flytouch 3 + funda-teclado VIGO)
16. escarabajo (Zenithik z102 + teclado)
17. sk (Zenithink Z102 + funda-teclado Bilbao)
18. Mikelone(Flytouch 3 + funda-teclado VALENCIA)
19. elmoscón (Flytouch 3 + funda-teclado Asturias)
20. ibiltari (Flytouch 3 + funda-teclado Durango-Vizcaya)
21.hankok ( Flytouch 3 GIPUZKOA )
22. gastonjp (Zenithink Z102 + funda teclado - Palencia) 2 tablets y dos teclados
23.jabalinketevi ( Flytouch 3 + funda-teclado ALAVA)
jabalinketevi
jabalinketevi
Octubre 24, 2011, 18:39:22 pm #387 Ultima modificación: Octubre 24, 2011, 23:51:27 pm por jabalinketevi
Hola mensaka, tas hay? Una pregunta la tableta donde la actualizo con el Tim ese. .loco2
kalimalaga
Hola compañeros, si quepo, ahí voy
6. casper30
24.Kalimalaga (Flytouch 3) Málaga
Si quieres ir rapido, camina solo, pero si quieres ir lejos, hazlo acompañado.
Morfina
Octubre 24, 2011, 19:50:17 pm #389 Ultima modificación: Octubre 24, 2011, 21:26:13 pm por Morfina
Bueno, pues a última hora pero me apunto
6. casper30
24. Morfina(Zenithik z102 + funda teclado) Barcelona
