Zona Técnica => Accesorios => Mensaje iniciado por: Halleck en Enero 16, 2008, 23:34:17 pm
Título: Inversor de 5000 W con pico de 10000 W !!!
Publicado por: Halleck en Enero 16, 2008, 23:34:17 pm
Me estaba dando una vuelta por ebay y me encontrado con esto  :o :
http://cgi.ebay.es/5000W-Spannungswandler-Inverter-Convertisseur-12V_W0QQitemZ220179648763QQihZ012QQcategoryZ125067QQcmdZViewItem
Copio aquí el anuncio para cuando se borre de ebay:
5000Watts/10000Watts Inverter 12V-230V
with Warranty and Invoice
This DC/AC Power Inverter lets you operate your laptop, TV, DVD players or other electrical devices using your vehicle's 12V power outlet!
A single AC outlet powers and/or charges a notebook, portable DVD player, game console and other AC accessories while the cigarette lighter socket provides DC power.
-protect the unit and also provides storage for cables and fuses
-Overload indicator (LED activates when inverter becomes overloaded)
-Low voltage, overload and thermal shutdown protection
-Reverse polarity protection
Certified in accordance with CE
Production certified in accordance with ISO 9001
Certified in accordance with (emark)
Model................................HI 5000Watts
Max.  Peak power................10000Watts
Input Voltage.....................10V-16Volts
Output Voltage...................220V-230V-240Volts AC
Low Power Alarm and Fan.....yes
Low Power Alarm.................10,5Volts
Size..................................465x165xx135 mm
Weight..............................8.90 Kg Date of Manufacture: 2007
Precio: 489,90 € + 18,50€ portes
(http://www.solarworld24.com/ebay/4000wattinverter.gif)
.loco2 .loco2
Para los que estaban pensando en lavadora, lavavajillas, secadora, horno, jacuzzi  .meparto
seguro que alguno se pone a hacer cuentas jajajjjajajajaja
un saludo ;-)
Título: Re: Inversor de 5000 W con pico de 10000 W !!!
Publicado por: KOYI en Enero 16, 2008, 23:37:03 pm
Vaya bicho león! ahí puedes enchufar una central nuclear. .meparto
Publicado por: tatxen en Enero 17, 2008, 01:25:26 am
O sea que se merienda una bateria de 200Ah en menos de media horita jeje y eso si fuese una bateria de gel, porque de las normales necesitaria casi 1600Ah en baterias para funcionar una hora, joe que bicho
Publicado por: Halleck en Enero 17, 2008, 01:32:30 am
Cita de: tatxen en Enero 17, 2008, 01:25:26 am
no, no?  .confuso2
5000 W = 220 .I
I= 22,72 A max
220/ 22,72 = casi 10 horas no?
o es que a estas horas ya no carburo  .loco2  .meparto
p.d: y eso fucionando al máximo es decir:
                  - cafetera express 1000W
                  - Calentador de agua a 220 600 W
                  - Ordenador portatil 150 W
                  - Secador de pelo que te cagas 1000W
                  - Lavadora 600 W
                  - que todabía me faltan 1650 watios..... iluminar un campo de fútbol?  .loco2
y entonces 10 horas tiki tiki tiki tiki
jajajjjajjajjajaja......
es que a estas horas...
Publicado por: francisco en Enero 17, 2008, 22:49:47 pm
A ese bicho si le metes consumo te dura la batería lo que tardes en darle al interruptor. ;D ;D
Es mucha caña. Yo con el de 1000W si me decuido dejo las baterías a la pata coja en un tris y eso con el motor en marcha.
Publicado por: zakariaslekunberri en Enero 17, 2008, 23:24:58 pm
Uff 10000W a 12 V son por el lado de la batería 800 amperios. Hace falta un cable de muchísima sección para aguantar eso. Parece más que una fuente de alimentación una fuente de problemas
Publicado por: Blanco en Enero 17, 2008, 23:31:53 pm
Hala ,................... que bestias,.....................para que tanto,.................... que llevais vitroceramica .meparto
Publicado por: twiki en Enero 17, 2008, 23:38:35 pm
pero que llevais en las furgos ?? Hornos piroliticos o asi ??  .loco1 .loco2 .loco1
Publicado por: Halleck en Enero 17, 2008, 23:49:21 pm
Cita de: twiki en Enero 17, 2008, 23:38:35 pm
Cita de: Blanco en Enero 17, 2008, 23:31:53 pm
Cita de: Halleck en Enero 17, 2008, 01:32:30 am
;D
Cita de: zakariaslekunberri en Enero 17, 2008, 23:24:58 pm
para 12 V no necesitas el inversor, que quieras consumir 5000W, 10000W o 1000000W depende de ti  ;)
nadie quiere ponerle una cafetera express a la furgo y su txabala necesita "imperiosamente" llevar el secador de pelo industrial, además de agua caliente para invierno??   .meparto .meparto
Publicado por: Halleck en Enero 18, 2008, 00:02:57 am
Cita de: tioguiller en Enero 17, 2008, 01:54:50 am
uno como este he montado hace unas semanas en una furgo-taller.
y qué batería le has montado?   :o :o
Publicado por: Halleck en Enero 18, 2008, 04:48:23 am
Cita de: tioguiller en Enero 18, 2008, 00:32:27 am
Directo a la de la furgo, con cables de alta tension y protecciones antirretorno "feito na casa".
I EZO QUE EEEÉ??  .confuso2 .confuso2
Como un diodo pero a lo bestia?... un diodo de potencia?  .confuso1
